Tractor Talk Discussion Forum
Ford 860 12 volt conversion/ positive ground
Dave H
12-13-2003 04:12:43
I have an 860 that I am going to put the single wire alternator on, I want to leave it as a positive ground since my 850 is a 12 volt positive ground and I don't want any jumper cable screw ups at some point. The problem I am faceing is the 850 has a generator so I can't compare the wireing. I want to be sure that I don't have to make any wireing changes to the alternators installation other then hooking the alternator return to the negative as opposed to the positive terminal. Thanks guys Dave
Jim WI
12-15-2003 10:44:22
 Re: Ford 860 12 volt conversion/ positive ground in reply to Dave H, 12-13-2003 04:12:43
While positive-ground alternators are available, they're not real common and you'll pay more for it.
I'd go with a negative-ground conversion.
RickB
12-14-2003 03:47:38
Like George says, your 12V pos ground 850 with generator should be changed, too. Finding a pos ground alternator for the 860 can be done, but then you have two oddballs instead of just one. Do the neg ground on the 860, and consider a neg ground regulator from a X01 diesel for the 850. Swap the ammeter leads, install and polarize the neg ground VR, and go.
george
12-13-2003 09:37:19
This is news to me. Your tractor should be 6 volt positive ground originally. When the 801 series came out they went to 12 volt neg ground.
Jim.UT
12-13-2003 11:33:30
 Re: Re: Ford 860 12 volt conversion/ positive grou in reply to george, 12-13-2003 09:37:19
The 801 was 12 V negative ground ONLY on the diesel models. The gas 801's were still 6 V positive ground.
Rlach
12-13-2003 07:47:10
Why don't you play safe ? transform your 850 in 12 V negative ground and be universal ! You just have to polarize the generator, reverse polarity on the ammeter, ... By the way, with your 12 V positive ground, did you respect the polarity of your coil, i mean the spark jumps from central electrode to the ground electrode ? if it is not polarized correctly, you will observe central electrode erosion.
Just my 2 cents. Rlach
George G
12-13-2003 05:18:00
Can't wire a alternator to a positive ground system. You have to change it over to negative ground system. I don't know if Ford uses a charge rate switch (three position, lights,low,high charge switch). If they do, you would have to replace it with a regular light switch.
Course, if you want to try to hook it up to positive ground. Make sure you have a spare alternator and enough wire to rewire the tractor when your done.
