Tractor Talk Discussion Forum
560 LP Gas Swithch to Gas to Sell??
farmall farmer
12-11-2003 16:03:31
Have a 560 LP Gas and want to sell it as I no longer have a need for it. Do you reakon it would bring enough more to pay for the parts to put it on Gasoline?? I realize this tractor is more than likley going to a "hobby farm" and I feel the "LP Gas" will scare buyers off unless I switch it to Gasoline. But personally I would rather have LP Gas as it will not get moisture or condinsation if left half full or empty over a period of time.
paul
12-12-2003 06:10:08
 Re: 560 LP Gas Swithch to Gas to Sell?? in reply to farmall farmer, 12-11-2003 16:03:31
While LP often sell for less, I think you will be better to leave it as is.
Is there enough power on a 560 to run a 500bu GT batch corn drier? Nice to use an LP tractor for the LP drier.....
--->Paul
don't know
12-12-2003 08:49:58
 Re: Re: 560 LP Gas Swithch to Gas to Sell?? in reply to paul, 12-12-2003 06:10:08
right after overhaul 4 years ago I took to the Case IH dealer and they checked it out and adjusted the carb and timing and it went from 36 to 48 hp and has ran about 1300 hours since. I mostly used it on a tailwater pump and since the water has sold and I feel no need to keep it. Ran a 8 inch lift pump and pumped water in 10 inch gated pipe to irrigate corn and it did that easliy.
Ron 1456
12-11-2003 17:19:43
I would leave it alone and sell it as an LP. You are almost always better off leaving things as thay came from the factory. If you sell to someone on an acreage they will probably have a propane tank for their house. When the delivery man come to fill the house tank they can have him top off the tractor also.
Nebraska Cowman
12-11-2003 16:08:02
I would love to have a propane 560. Bet there is lots of other collectors that would like it too.
for Nebraska Cowman
12-11-2003 20:28:00
 Re: Re: 560 LP Gas Swithch to Gas to Sell?? in reply to Nebraska Cowman, 12-11-2003 16:08:02
if you would be interested in the tractor email me. I would like to talk to you.
