Tractor Talk Discussion Forum
Ford 6700
TURTLE
12-08-2003 09:35:13
Went and looked at a JD 2130 and decided that it was junk. But I noticed a ford 6700 that was in good shape, and was courious if there are any special things that these beast would have problems with that I should look for? When started It does sound like it is knocking, but only when it is in nuetral and not in gear. Are front end loaders availible for this? As always thanks in advance.
Rod F.
12-08-2003 15:41:35
 Re: Ford 6700 in reply to TURTLE, 12-08-2003 09:35:13
The noise may be the dual power. That is probably normal, if it is in high (direct). Should be less noticable in low (underdrive). Just check everything over. Hyd pumps after 5000 hours, and power steering pumps if they were not maintained can cost a bit. Spindles on 2 wheel drives. Like anything, there could be lots of trouble or no trouble. Take care.
Rod
