jdemaris
12-05-2003 18:38:15
Re: Re: Re: Closed center hydrolics in reply to Paul, 12-05-2003 10:00:11
A lot of John Deere equipment uses closed center. When I worked as a JD mechanic, I was often taught at Deere school that the closed center system was better than open because there was always high pressure oil at the control-valve, ready to use, and therefore response was faster. Sounds good, theoretically, but in my real-life experiences, I can't feel the difference. As I recall, the term "closed center" refers to the center of the main control valve being normally closed, whereas, and "open center" has a control valve that is normally open, so oil flows through it all the time with virtually no pressure - until a function is used. My own opinion is, the open center systems are simpler and work just as well as closed center systems. And, open center systems don't cause the engine cranking and starting problems often associated with closed systems. One other benefit to open-center is that the components, especially the pumps, are usually generic and easily replaceable. Webster pump craps out, just replace it with a Cesna or Vickers, etc. On the other hand, closed-center systems often utilize proprietary components. Take a John Deere closed system, especially an older one, and try to retrofit a pump, steering valve, or selective control valve with anything but a John Deere component and you'll be out of luck.
