Tractor Talk Discussion Forum
need help hooking up tach on allis chalmers -b
wilburn
12-02-2003 16:38:49
i have a allis chalmers -b with a magneto .is there any way i can hook up a tach to it.if there is ,can some one tell me how to do it. thanks
Gene Davis
12-02-2003 19:03:12
 Re: need help hooking up tach on allis chalmers -b in reply to wilburn, 12-02-2003 16:38:49
First you have to know if it is a magneto or distributor ignition, the distributor would be simple, just buy an automotive kit and follow the instructions. To use with a magneto,you will need to find an inductive type tachometer that clips over the spark plug wire like a timing light, and generates a signal from it. I have one that was a kit bought long ago from the Heath Mfg. folks, not sure they are still around anymore. Probably the only other way will be a mechanically driven one.
Gene Davis
