Tractor Talk Discussion Forum
JD B head removal
Don Hatton
11-28-2003 18:18:51
Any pointers on how to get the head off a JD B? Tried rubber mallet, longer pry bars, WD40, 2 cans, small torch, comealong on water pipe studs. Head will slide about 1 inch forward.
John Ne.
11-29-2003 06:47:10
 Re: JD B head removal in reply to Don Hatton, 11-28-2003 18:18:51
My 42 B has a cast piece between the frame rails just infront of the head, had to remove the head bolts, to get it all the way off. The cast cross piece prevented it from sliding all the way off the head studs. John in Nebr.
George
11-28-2003 19:43:15
Try running a tap down the stud threads to remove any burrs and lead washer residue.
Gene Davis (GA.)
11-28-2003 18:49:15
Be sure you have all the rust cleaned off the studs then oil them good, and all the trash & crud off the frame rails. Gene
Steve450
11-28-2003 21:18:40
 Re: Re: JD B head removal in reply to Gene Davis (GA.), 11-28-2003 18:49:15
Is this a cyclone B??? If so , you have to remove the frame to get the head off.
JerryB
11-29-2003 05:43:26
 Re: Re: Re: JD B head removal in reply to Steve450, 11-28-2003 21:18:40
Steve, don't be rediculios, you don't have to remove the frame to remove the head.Jerry.
Gene Davis (GA.)
11-29-2003 18:36:56
 Re: Re: Re: Re: JD B head removal in reply to JerryB, 11-29-2003 05:43:26
We always took the late model (pressed steel frame)"B" heads out the bottom between the rails.
