Tractor Talk Discussion Forum
cause of vibration
al bane
11-25-2003 15:13:04
I have a diesel tractor and had it overhauled and it has a vibration in it.It was there also there before the overhaul.Wonder what could cause this.The motor is a CONTINENTAL in a Farmall tractor.
Tony L.
11-25-2003 19:25:26
 Re: cause of vibration in reply to al bane, 11-25-2003 15:13:04
possible causes for excessive engine vibration:
1. Faulty vibration damper
2. Unbalanced or loose flywheel
3. Main bearing bore out of alignment
4. Engine due for overhaul
5. Misalignment of engine with driven unit
6. Loose mounting bolts
david val
11-25-2003 22:08:56
 Re: Re: cause of vibration in reply to Tony L., 11-25-2003 19:25:26
add to the above unbalanced clutch.
david
a bane
11-25-2003 19:41:12
Where is the vivration damper located.I have a repair manual but doesn't show it.Thanks-a bane
Tony L.
11-25-2003 21:50:10
 Re: Re: Re: cause of vibration in reply to a bane, 11-25-2003 19:41:12
Hi,
these are points I took out from a trouble-shooting chart for diesel engines.
If there is a vibration damper, it will be located on the crankshaft, beside the drive pulley. But I dont think there is one, I have a ford 3000 and a white 1470 and they dont have one. It is used in much larger diesel engines. You have to be sure it is engine vibration and not engine roughness, because these are two conplaints that lead to different diagnostics.
If you give me you email adress, I can post you two diesel engine trouble charts that I have in order to help you out. Do you have your engine model or cyl bore and stroke, maybe I can get some info about that engine.
[email protected]
al bane
11-26-2003 03:10:30
 Re: Re: Re: Re: cause of vibration in reply to Tony L., 11-25-2003 21:50:10
E-mail me on the possible cause of the [email protected] -- thanks
