Tractor Talk Discussion Forum
Want to Talk to Experienced Engine Rebuilder
moonlite
11-23-2003 16:31:13
I have rebuilt several engines and have always been told that for long reliable service that a crankshaft should not be ground more than .020. I know that there are engines of similar size, speed, and performance which may have crank journals much larger than others so it would seem unreasonable that a crankshaft is designed in such a way that it could not perform if the journals were much smaller. Could it be that the surface of the journal has some different characteristics in the metal than the inside portion of the shaft? Are there other considerations other than difficulty in finding bearings. I heard of an old GMC truck shaft which was ground to .060 and they had to make a bearing for it. Even the mechanic who did the work doubted it would hold up.
Tony L.
11-27-2003 14:37:38
 Re: Want to Talk to Experienced Engine Rebuilder in reply to moonlite, 11-23-2003 16:31:13
Reconditioning pins and journals
3 principal methods are employed for reconditionnning the crankshaft pins and main journals (a)grinding to underzise dimensions, (b)metallizing the surface to original size and (c)chrome plating to original size. Building up surfaces by submerged arc welding is also used but to a lesser degree.
When grinding undersize, bearing journals are ground and polished to original specifications and standard undersize dimensions. Journals can be re-hardened if necessary but in regrinding to standard undersizes, depth of the original hardening is generally adequate to retain hardness.
Diesel engineering handbook.
Nate
11-26-2003 19:51:54
Moonlite, I myself would not worry about putting .60 bearings in a Farmall H but in my pickup I might find a new crank. As you grind the crank you take off more of the hardened material. Which in turn your bearing are thicker. The more bearing you have (since it is softed than the crank) the more it can smash. Like I said. I wouldn't worry about and old tractor but I wouldn't do it in my daily driver
george md
11-26-2003 22:44:54
 Re: Re: Want to Talk to Experienced Engine Rebuild in reply to Nate, 11-26-2003 19:51:54
Nate ,
It appears that you are quoting the old crank myth , read the post below. Undersize bearings do NOT have thicker bearing material, they have the same amount of bearing material, but have thicker steel backing .therefore the strength of the bearing has not changed. Most automotive engines and the older tractor cranks are not heat treated or surface hardened, so grinding deeper is not a problem . Grinding is not the problem , why it had to be ground can
be the problem . Heat treated cranks that have
had a heat related failure are subject to a change
in the hardness or strength due to excessive heat.
Those with nitriding or tufftriding come with a completely different set of guide lines . Basically ,if the shaft is not nitrided and is not a heat treated shaft with a heat related failure , you can grind it to any size that you
can buy bearings to fit. george
Mr. Goodwrench
11-24-2003 20:15:24
Well, Moonlite. There you have it. Over a dozen shadetree experts, machinists, and rebuilders have given you their years of accumulated experience and wisdom. And did the chorus all sing with one voice? HECK NO! They all seem to have different answers and different reasons for having those answers. The real answer is this. Every crank is engineered, cast, machined, hardened and ground for a specific application which will operate under a projected set of parameters. A high revving V8 ego booster and a slow turning high torque 1950's diesel operate in entirely different regimes with tremendously disparate loads, stresses, rotational velocities and temperatures. THERE IS NO RULE OF THUMB TO TELL YOU HOW MUCH YOU CAN SAFELY GRIND A CRANK WITHOUT SACRIFICING SAFETY OR SERVICE LIFE!!!!!
So the intelligent thing to do is, refer to the specifications and advice given in the MANUFACTURER'S shop service/overhaul manual( not I&T, the real service manual). The recommendations and limits given there will be made with respect to the specific crank that you have and will have passed in front of the engineers and metallugists who designed the durn thing and know how much weakening will occur. They have a good handle on when to regrind, how much you can regrind, and when to scrap the thing because further regrinding will be a losing proposition. Now how many of those well meaning, self proclaimed experts want to argue against that recommendation? Listen, one time I read a post where one of these city boy genius mechanics was trying to find out which tractor had the thickest cylinder sleeves, so that he could bore it out 1/16" and make a puller ot of it. He couldn't for the life of him understand why I and another fellow told him BAD IDEA. He knew so little that he didn't know how little he knew! BE CAREFUL following the advice of these 'been there, done that" types. Follow the manufacturer's spec's and advice and let the shadetree boys sit around the gas pumps and ruin their own equipment. GOOD LUCK, Mr. G
Chris-se-ILL
11-29-2003 06:55:21
 Re: Re: Want to Talk to Experienced Engine Rebuild in reply to Mr. Goodwrench, 11-24-2003 20:15:24
It would seem that you still believe that grinding .060 undersize (taking .030 off of the radius of a crankshaft) will weaken the design and strength of the crankshaft to the point of breakage. If that .030 of flame hardened metal (less than the width of the gap of most sparkplugs) along the outside edge of the journal, is all that is keeping a crankshaft from breaking at the maximum torque upon the crankshaft (in other words the tolerances are so close, at that point of removing material, that the allowable safety margins are negligable)... well that just impresses the crap out of me! That is some strong .030 of metal!!!
And to think... I thought that just the outer surface of the crank was hardened (usually somewhere near .100 thick on the radius) in order to resist the abrasive wear from contaminants in the oil. Now I learn that it is hardened to resist the inherent torque of the engine. If the designers needed strength from hardening the crank... then why didn't they just harden the entire radius of the metal (hardened to the core of the crank)? Maybe it is because they want some "flex" to the crankshaft so it won't break from the torque stresses.
I believe that there are folks like you that believe that the hardening (tempering) of the surface (bearing face) of the journals is for the purpose of extra torque strength (strength against twist). In my opinion, your belief of such... is a falacy! It makes almost no design sense to just harden the bearing surface area to add strength against torque! Especially since there is no "surface hardening" on any other part of the crank except the bearing faces... the webbing and connective material between the journals usually have no surface hardening whatsoever! They are usually just rough cast!
It does however make sense to temper the bearing surface area in order to resist errant abrasion from particulates in the lubricant!
School of Hard Knocks
11-28-2003 20:09:27
Mr. Goodwrench, Sounds like you and Dr. Phil both think you are God's gift to to everyone that doesn't know better. Get a life (BOY), -"If you learned it hands on, crow, - if it came from the engineer's books, -learn some more from those who know better!
well said sir
11-28-2003 23:10:43
 Re: Re: Re: Want to Talk to Experienced Engine Reb in reply to School of Hard Knocks, 11-28-2003 20:09:27
Best answer yet !!!
Manual/CD
11-25-2003 06:26:20
Interesting your speaking of getting the manuals when GM seems to only be producing CD's now for their vehicles instead of paper manuals.
Mr. Goodwrench
11-25-2003 20:33:45
 Re: Re: Re: Want to Talk to Experienced Engine Reb in reply to Manual/CD, 11-25-2003 06:26:20
What does GM have to do with the subject in the posting? You must have assumed that I have a connection with General Motors because you watch too much television. The only exercise some people get is jumping to conclusions. Mr. G
from George in Maryland
11-24-2003 09:40:39
third party image
This is the crank maximum grind myth referred to by George from Maryland below.
Chris-se-ILL
11-24-2003 08:16:37
Well, you found an old crank-grinder! Back in '79 - 82 I worked in an automotive machine shop in Champaign, Ill. We did it all, including complete rebuilds (the engines were on stands, we did no "on vehicle" repairs) The myth of grinding past .020 is bunk! I have ground many cranks past the .030 in order to clean up the journals.... never had one come back!
We used Sealed Power, Federal Mogul and Perfect Circle bearing books (still have some of those parts books) for guidelines on what was available in bearing sizes. We ground old tractor cranks (many for '49 and older pulling tractors, one year three tractors went to the State pulls in Springfield and won 1st, 2nd, and 3rd), and all types of truck and automobile cranks. Some of the cranks that were too large for our crank machine would be sent to "Effingham Regrinding" in Effingham Illinois (if you really want an answer to your question, call them. They are still in business!)
As for the surface hardening... Yes cranks are surface hardened but according to most of the tech info that I ever read, most of the surface hardening was at least .070 to .100 deep (that is on a radius) Where as grinding .060 off the crank only removed .030 off the radius. We tried to not grind to .060 "because" it was such a pain in the backside (took too much time, we worked on commission). Plus, if a crank needed that much taken off it was usually due to burning a bearing (and extremely galling the crank) and if it was burned and galled bad enough to warrant turning that far... the crank was probably bent (twisted) anyway! So we usually recommended either sending it to Eff. Regrind. to be checked out (including magna-fluxing, straightening, and regrinding).
The process of grinding a crank uses a "wet" grinding wheel and a stream of coolant on the journal as it is ground (cut). There is no loss of surface temper unless some operator tries to rush the grinding job and starts heating the journal face (which will take the temper out of the face). A machinist will use his ears to tell just how a cut is progressing (can tell instantly if there is a slight change in sound) along with watching the surface and using a special "swing-away" micrometer that is fastened right to the machine. The mic can be swung into position and will give a constant reading as metal is removed so that the cut will be accurate. I HAVE NEVER "heard" the stone change pitch as it would if it were to cut beyond the tempered face of the journal. And believe me, a machinist CAN tell by the "singing" of the wheel how it is cutting.
As I said, we ground a lot of cranks, most between .020 and .040 (that is .010 to .020 on the radius) and some to the .060 size with NEVER a return. The shop had been in business since the late '30s.
The shop closed it's doors sometime in the late '80s because it was bought out and liquidated by another company. A lot of that happened back then!
JOHN (LA)
11-24-2003 20:33:44
 Re: Re: Want to Talk to Experienced Engine Rebuild in reply to Chris-se-ILL, 11-24-2003 08:16:37
Please do not use that word(Champaign, Ill)in my presence. LOL!!!!!
It reminds me of the four months I spent in Rantoul Ill. Stood on hood of my car once and could only see corn in every direction.
Only good thing I found in Champain; Urbana area was going to the bar chasing college girls and getting some water in a beer can. (Think you all call it 3.5 beer)
Dam I'm getting old. Was 19 then and now have a son 22.
Have a great day!!!!!
Chris-se-ILL
11-25-2003 06:36:43
 Re: Re: Re: Want to Talk to Experienced Engine Reb in reply to JOHN (LA), 11-24-2003 20:33:44
John, you may be close to my age (more or less). I was about 19 when I moved to Urbana (and I spent about 5.5 years there). My oldest is about 21 and married now.
"Sixth and Green" was the place to be during the summer time up there (the traffic was slow though). College girls running around in shorts.... Never visited any bars, and didn't like the taste of beer (still don't) but I would drive near campus about everyday on my way home for lunch those first few years.
And now, I live in southern Illinois with corn fields outside my front door... MY corn fields! I will take corn fields anyday, as opposed to city life!!! ;-)
Earl S.
11-24-2003 18:59:16
Chris where do you live now?? Did you work for me ? Earl Seamands (Stewart Auto Parts)
Chris-se-ILL
11-25-2003 06:26:25
 Re: Re: Re: Want to Talk to Experienced Engine Reb in reply to Earl S., 11-24-2003 18:59:16
I was wondering if the Earl S. was you!
Yup, I worked for ya... Never did hear the full story about what happened to the shop. Just rumors! I had left the area by the time it closed. And I never believe rumors too much. Always wondered what happened to you and the store!
Do ya still have the "G"?
I live about 100 miles south of Champaign now! Been farming for the last 20 years! Dad retired in '87 and I saw the opportunity in '84 to quit the automotive mechanic life and get back to my roots... farming!
When I left the Champaign/Urbana area... I never looked back! :-)
Good to hear from ya!
Earl S.
11-25-2003 16:18:49
 Re: Re: Re: Re: Want to Talk to Experienced Engine in reply to Chris-se-ILL, 11-25-2003 06:26:25
I had two people by the name of Chris work for me.e-mail a fill me in on your last name and what years you worked and who was in the shop.Are you collecting old tractors? What kind do you like? I am still playing with old tractors and teaching part time at Parkland. Earl
Chris-se-ILL
11-25-2003 21:39:39
 Re: Re: Re: Re: Re: Want to Talk to Experienced En in reply to Earl S., 11-25-2003 16:18:49
I didn't realize that there was another Chris that had work for ya! I am Chris B., the one that worked there running the shop when Bob Feller went to work at I.C. I worked there from Oct '79 thru Jan '82. Kurt Gosser was working there, when I quit to go work at Sullivan Chrysler Plymouth, in Urbana.... Does all that ring a bell? :-)
I can't say that I am "collecting old tractors" ...that is, none of them are for restoration purposes. I own 7 tractors and a IH1460 combine. All red! 28 hp up to 190+hp All the equipment is for farming purposes, even though the newest tractor was made in '78. I also own 135 acres, 2 planters (corn planter and bean planter) and various assortment of implements (these are mostly all red too!). I farm over 350 acres all by myself... corn, soybeans and hay! Plus, I drive a semi hauling propane in the wintertime for a propane supplier.
Bill(IN)
11-24-2003 06:56:10
Surface hardening is just what it implies. It is very thin and any grinding removes it, that's part if the reason bearings are made of soft material. I have built many racing engines and turned the crank journals down to use rods from other engines that had smaller rod throws. It is common practice to offset grind rod throws for a longer stroke, taking a lot off of the back side of it. As long as it is done properly, it isn't a problem. My 2 cents worth
gatractorman
11-24-2003 03:07:43
I wont go past .030 and dont like to go that far, I would like to hear opinions on building crankshaft up and turning back to standard, seems that this is done quite often nowdays, reground or something like that they call it, I have used 1 of these shafts in an 8N and it failed.
stan
11-23-2003 23:28:29
I have been doing my own repairs, and rebuilds all of my 61 years. I was never afraid to ask questions when in doubt. I was always told never go over .030. I have a crank in my El Camino with a .020 on the rods (one welded back ot size) and .030 on the mains. It has close to 100 thousand on it. since the rapair. If possible .020 would max for a rod. on a auto. But would go .030 on a low rpm tractor without loosing a wink of sleep. Tomorrow I will need to make the same decision on my MF 231 when I pull the motor.My 3three cents.
Jim was in UK
11-23-2003 22:30:10
I haven't done an engine rebuild in over 18 years. I do recall putting more than one reground crankshaft into engines though when I was working in the shops. It is (well at least then it was) preferred not to install a crankshaft that was ground more than .30 but have installed them ground to .60 and some of them lasted as far as I know until now. I know of only one of them that had problems that was ground to .60. It was in a JD 4620, That ran for about 4 years before it gave up. But then again, there were a lot of other contributing factors. The Farmer that owned it did not keep up on the maintenance very well and it had oil in it that looked more like something used for paving highways.
george md
11-23-2003 19:57:18
Moonlite , If you want a copy of that myth and the answers to it , send me a email .
there are a few nitrated shafts that if ground need to be renitrated . The tuftriding is very shallow but the old nitriding was .015 to .017 deep and could be ground .010 .
george
Chicken Choker
11-23-2003 19:32:35
Better keep to the "Chibbies' Mr. Goodwrench! Ain't no room for you in a "real" shop in the country.
gene b
11-23-2003 19:15:30
If all the engines now running would stop running that have been ground undersize there would be the greatest traffic jam on record. What other silly words of wisdom have you heard about grinding cranks so you and MR.GOODWRENCH can both learn something.
Phil Munson
11-23-2003 18:40:11
Depends on the particular engine and how well it was designed and built, and how well the crank is reground. There is an IHC farmall H in the neighborhood that was turned .060; about forty years ago, and still going today. If cranks are not properly dressed, especially in the radius, they can be easily broken.
Nate
11-26-2003 19:42:12
 Re: Re: Want to Talk to Experienced Engine Rebuild in reply to Phil Munson, 11-23-2003 18:40:11
There such a high performance engine.
Mr. Goodwrench
11-23-2003 18:30:28
You came to the wrong place. These guys are all plumbers and shadetree mechanics. Half of them are transplanted city slickers.
Ben in KY
11-24-2003 10:12:56
 Re: Re: Want to Talk to Experienced Engine Rebuild in reply to Mr. Goodwrench, 11-23-2003 18:30:28
Mr. Goodwench apparently thinks this is one of the toy (compact) tractor sites :)
Chris-se-ILL
11-24-2003 09:17:10
Welp Mr. Goodwrench... I think you just "slipped a cog." If you were being serious you missed it! I for one ran an automotive machine shop (in Champaign, Illinois) and have experience grinding cranks... among many other talents. Valve jobs, Boring, honing and fitting wrist pins, crank grinding, cylinder boring and sleeving, piston on rod installation, head milling/planing, hot tanking, porting/polishing, guide and seat replacement, flywheel grinding, rotor and drum turning, custom engine modifications.... We had folks calling from as far away as SD, IA and NE for us to modify their JD-G engines for pulling tractors (cost $1500 just for cylinder/piston and head modifications).
So if you were serious... you missed the target!
george md
11-23-2003 19:48:46
Goodwrench, Before you accuse these fellows of being incompetent you better look in the mirror . Being a goodwrench says that you are a highly trained parts changer, it did not say that you are a mechanic . You guys change starters and fuel pumps,when I started wrenching we had to rebuild those items . I put many kits in fuel pumps ( valves and diaphrams ) in cluding the double diaphram one that helped run the wipers . I am an engine rebuilder and have an automotive machine shop , more than half of my work is truck, industrial , and tractor. I noticed that you did not debunk the myth about grinding cranks more than .010 or .020 .
If someone will post it ,I have a copy of the myth and the answers to it . I would but don't know how , can email to someone who will .
george
Steve - IN
11-24-2003 03:48:39
 Re: Re: Re: Want to Talk to Experienced Engine Reb in reply to george md , 11-23-2003 19:48:46
george,
I can post it for you.
Also, I noticed you mentioned salt bath nitriding - adding nitrogen to steel or iron - which makes me think you know what you're talking about.
RJ-AZ
11-23-2003 19:37:02
I am ASE master certified in automotive, heavy truck and truck equipment fields. MOST automotive crankshafts are nodular iron and are surface hardened. By turning more than .030 under size you can get down through the hardening. A lot of tractor and diesel truck crankshafts are forged steel and operate at lower rpms and can take more machining and still live. It all depends on application. MY2CENTS
raytasch
11-23-2003 18:39:28
So where did GM's Mr Goodwrench learn anything about tractors, in the city.
ray
raytasch
11-23-2003 18:28:35
I, too, have heard the stories about not going less than .030 under. I've heard the hardening stories. I have seen low speed engines run with .060 undersize and do well for many hours/years. I have in my shop two sets of Federal Mogul bearings for a Ford N engine that are .060 under. Main# 567 M 60 and rods are 1055 CP60. Going .060 under is not my idea of the ideal situation but I figure someday I or someone will be glad to use them.
ray
marlowe
11-23-2003 17:26:45
shoud not grinde more then .030
Rob
11-23-2003 16:59:35
I'm not a pro engine man but I believe the following is correct. The crank journals are surface hardened at manufacture. If it's turned down, the hardening will be removed. Re-hardening should be possible. HTH.
