Tractor Talk Discussion Forum
Smoking D-10 Allis
Scott in SC
11-20-2003 12:54:46
Have a D-10 Allis. It smokes like a freight train. Checked the compression. 130-140 lbs on all cylinders. Isn't that plenty? If so, where is the oil coming from????Thanks in advance, Scott
Marlboro Man
11-20-2003 19:39:14
 Re: Smoking D-10 Allis in reply to Scott in SC, 11-20-2003 12:54:46
Take its cigarettes away and give it a lecture on the dangers of smoking.
Funnyman
11-21-2003 03:44:14
 Re: Re: Smoking D-10 Allis in reply to Marlboro Man, 11-20-2003 19:39:14
There's one in every crowd.
Indydirtfarmer
11-21-2003 04:53:38
 Re: Re: Re: Smoking D-10 Allis in reply to Funnyman, 11-21-2003 03:44:14
You got a whole room-full of 'em here.
Joe
11-20-2003 18:11:09
Gas or diesel?
Scott
11-21-2003 03:31:27
 Re: Re: Smoking D-10 Allis in reply to Joe, 11-20-2003 18:11:09
Gas
waynesville
11-23-2003 01:06:58
 Re: Re: Re: Smoking D-10 Allis in reply to Scott, 11-21-2003 03:31:27
Could be several things. Might be a cracked oil ring,or maybe just bad oil seals on your valvles.I've seen bad seals on several allis's that have sat around for a while.
Scott in SC
11-23-2003 06:27:47
 Re: Re: Re: Re: Smoking D-10 Allis in reply to waynesville, 11-23-2003 01:06:58
Pulled the valve cover . There were oil seals on only 2 or 3 valves.I sent the head off to have the valve guides replaced and whatever else needed doing.Since I've got the head off, I'm going to go ahead and check the rings. Thanks for the advice. Scott
