Tractor Talk Discussion Forum
Bobcat Jaguar 4000 Mower
Brian in IL
11-20-2003 07:07:27
I just bought a Jaguar 4000 mower (hydrostatic drive) which had hydrolic leaks all over and barely moved foward and backwards. I was told that it was working fine before it started to leak. I have repaired both of the front cylinders that lift the mower deck and replaced the rear steering cylinder. I have no leaks now. The hydrolic fluid reservior was completly empty which I have now filled. I started it up and I can hear the hydrolic pump working but the deck cylinders do not work and the mower is not moving forward or reverse. The book I have for this mower is a maintenance manual and does not show me what to check to figure out whats wrong. Do I need to bleed the system? Could the pump be bad or is something damaged because it was out of fluid? I appreciate any help you might give. Thanks, Brian
Ken
03-25-2004 10:05:14
 Re: Bobcat Jaguar 4000 Mower in reply to Brian in IL, 11-20-2003 07:07:27
Did you find the problem ?? I just found one of these machines and I have the same problem ....
Just looking for a little help..
