Tractor Talk Discussion Forum
replacement of sleeves joints ( ford 4000 3 cyl)
fred
11-18-2003 22:54:09
I have a leaking sleeve joint (dry sleeves) at my ford 4000. Does anybody knows a procedure to replace new joints.
I know I have to remove the crankcase, the pistons but how to remove the sleeves and how to place the new joints?
Hope you can help
Fred Belgium
david val
11-19-2003 03:56:47
 Re: replacement of sleeves joints ( ford 4000 3 cy in reply to fred, 11-18-2003 22:54:09
do you mean seals (i think joints in french are gaskets)? usually dry sleeves do not have seals.
the ford engines i know (4600) do not have sleeves at all, but when cylinder wall becomes porus, the cyls. are bored and dry sleeves are pressed in and machined to standard. in any case, dry sleeves are mostly press fit and come as semi-finish. removal can be done by a special puller or by cutting them with the boring machine at the machine shop. new sleeves are then pressed in and cut and finished to the standard measurment.
david
fred
11-19-2003 13:37:40
 Re: Re: replacement of sleeves joints ( ford 4000 in reply to david val, 11-19-2003 03:56:47
I am almost sure that there are sleeves. I though all were dry sleeves. But it seems to have ring seals. So what is the type of the seals?
Alvin n Ms.
11-19-2003 09:38:43
To remove sleeve, just weld a bead around the inside of the bushing and than let COOL and it will come out.and when you want to install a new one ,put it in the freezer over nite and it should go in easy. This info was sent to me by Jim l
