Tractor Talk Discussion Forum
H Electrical System help
Gary
11-18-2003 17:42:19
recently i purchased a 1950 H that was half restored and I put it all back together except for the wiring. Changed it to a 12 volt generator ,battery ,voltage regulator. The wiring that was on it is shot .when I got it the wiring was not hooked up to anthing. Can anybody tell what wires go where.Or point me in the right direction.It has two lights,on /off switch,light switch,volt reg., generator,Starter switch.
Bob M
11-19-2003 04:19:04
 Re: H Electrical System help in reply to Gary, 11-18-2003 17:42:19
Gary- Punch below for a diagram that should work.
Note: If your regulator has only 3 terminals (i.e. it has "L" terminal like shown on the diagram) simply connect the ignition/light switch supply wire to the "BAT" terminal on the regulator.
Gary V
11-19-2003 19:11:56
 Re: Re: H Electrical System help in reply to Bob M, 11-19-2003 04:19:04
To Bob M Thanks for the diagrams.You are a great help
