Tractor Talk Discussion Forum
Rear hubs for a farmall H
Nathan Bolzeniu
11-18-2003 05:38:05
I have a set of stamped 9 bolt wheels I would like too put on my farmall H. The problem is finding a set of hubs. My axle diameter is 2 1/2 inches. The only hubs I found that will fit are off a john deere 420, but stick out way to far from the outside of the wheel. If you kmow of any model tractor, or any aftermarket company that has hubs that will fit please let me know.
old
11-18-2003 06:02:47
 Re: Rear hubs for a farmall H in reply to Nathan Bolzenius, 11-18-2003 05:38:05
I'm not sure if the H has clap on hubs but if it does you might look at some thing from an oliver, it looks to me like my oliver hubs will fit my Farmall F12. Hope this helps you some
wdTom
11-19-2003 18:32:44
 Re: Re: Rear hubs for a farmall H in reply to old, 11-18-2003 06:02:47
You may need a step key, try McMaster, they have some. Or you can have a buddy with a milling machine make you some.
