Tractor Talk Discussion Forum
900 Ford Tricycle numbers
Ronnie
11-17-2003 19:28:47
I have a 900 Ford Tricycle with the numbers 960-5 stamped on the block.I know what the 960 stands for but for the life of me can't find what the -5 stands for.Can anyone help me...Thanks.REA.
Jim.UT
11-18-2003 11:41:18
 Re: 900 Ford Tricycle numbers in reply to Ronnie, 11-17-2003 19:28:47
The 900 is the series number. Within the 900 series were a couple of different models. The 960 is the model number. The 6 in the middle of the model number tells you it has a 3 point hitch, 5 speed transmission with live pto through a dual clutch.
There has been some head-scratching about the "-5" that appears after some of the 960 models. I've finally come to the conclusion that the -5 means it came out of the factory with the optional wide front end. Standard equipment on that tractor is a tricycle with dual tires. Another suffix you might see is '-1' which is supposed to mean a single tire tricycle. However, there have been enough front end swaps over the years that the suffixes don't seem to mean a lot anymore. Lots of tricycle fronts have been swapped to wide fronts and vice versa.
Ronnie
11-18-2003 19:28:47
 Re: Re: 900 Ford Tricycle numbers in reply to Jim.UT, 11-18-2003 11:41:18
Thanks to Jim.UT.I was thinking along those lines but I was not sure. I could'nt find any information in my books to back it up.Thanks again, REA
Devin
11-17-2003 20:11:49
Maybe the five is for the 5 speed tranny????
