Tractor Talk Discussion Forum
1954 800 ford vane hyd. pump
Gary Alford
11-17-2003 17:01:19
I was wondering if any knows why ford went to the piston style pump after 1954. I have a 1954 with a vane pump that works good till the weather gets cold. Then you have let it run and rev. it up to get it to prime.
Jim.UT
11-18-2003 11:57:44
 Re: 1954 800 ford vane hyd. pump in reply to Gary Alford, 11-17-2003 17:01:19
I don't know the exact reason for the change other than the vane pumps were proving to be troublesome. Maybe you're experiencing the reason first-hand. The change was made just prior to the end of the '55 model year at serial number 66849.*
*According to Ford Shop Manual Supplement SE 6086-1-115510, Hydraulic Piston Pump, page 4.
Alvin n Ms.
11-18-2003 06:25:39
All the pumps that were installed under the operators feet, in the belly, are piston type. Ford went external in 1953, mostly because of a patent infringment lawsuit with Harry Ferguson, the inventer of the three point lift system.
