Tractor Talk Discussion Forum
chrysler and torque converters
bill
11-16-2003 07:28:54
I read about an odd tractor made in te late 40 earky 50 time frame which had a chrysler engine with torque converer Queston is this the same set up as dodge and plumouth fluid drive and does any one know where I could find one of these torque converters??? My grandfather hade a dodge pickup around1950 that he didnt use clutch after low gear . I seem to rember sonthing about Fluid Drive on the side.
Joe
11-16-2003 09:32:10
 Re: chrysler and torque converters in reply to bill, 11-16-2003 07:28:54
What is the difference between a torque converter and a fluid coupling as on the Dodge?
Allan
11-16-2003 09:53:02
 Re: Re: chrysler and torque converters in reply to Joe, 11-16-2003 09:32:10
Joe,
A torque converter has a set of variable pitched fins called a stator setting between the two sets of main fins, which allows the speed of the rotation to gradually change the torque of the driven side by that of the drive side.
A fluid coupler doesn't have this stater and relies more on a "shearing motion of the oil" to make or break its connection between the two sides. A fluid coupler is more of an on/off connector which is depending on speed of rotation.
Allan
Paul Janke
11-16-2003 08:48:43
I have one of these torque converters which I have been told needs to be rebuilt, or possibly just refilled with ATF. I have not investigated because I didn't need it or the brand new clutch to go with it which came as part of the package when I got a Scoopmobile for parts to fix my other one. If any of this will help you, please let me know.
