Tractor Talk Discussion Forum
730 case
Mitch
11-14-2003 10:31:27
would a transmission/rearend from a 830-930-etc fit on a 730? My 730 on LP lost a bolt and now I have a cracked case.
Jim Handke
11-14-2003 19:08:45
 Re: 730 case in reply to Mitch, 11-14-2003 10:31:27
I think the cases are all the same. The only difference was in the pinions. The 730/830 had three, the 930/1030 had four.
Roger
11-14-2003 19:51:03
 Re: Re: 730 case in reply to Jim Handke, 11-14-2003 19:08:45
Jim, what are you talking about when you refer to "pinions"?
John
11-15-2003 04:40:37
 Re: Re: Re: 730 case in reply to Roger, 11-14-2003 19:51:03
Differential gears or spider gears
Tony Weatherly
04-25-2004 18:07:36
 Re: Re: Re: Re: 730 case in reply to John, 11-15-2003 04:40:37
I have a 730 case disel. I'm looking for a hood & wide front end. I live in Falkner Mississippi. It runs great and I just want to restore it.
doug@upr
11-15-2003 13:59:23
yes they should interchange, the only thing that you may want to check is the pinion shaft bearing size if your just changing the case only, since i know on the 8-1070 series they increased the bearing size, though it might not be the case with the 30series
