Tractor Talk Discussion Forum
What is the SEASONAL DISCONNECT ?
Greasy John
11-13-2003 06:35:44
Got my 350 all apart and all I see in the hole where they mention it is a spline coupling for the LPTO. I dont know if that is what they are talking abt or not? Dont see how you could disconnect either way. John
Kelly C
11-13-2003 07:00:35
 Re: What is the SEASONAL DISCONNECT ? in reply to Greasy John , 11-13-2003 06:35:44
There is a lever on the underside of the transmision. When you move this lever to disconect position. It disconects the PTO shaft from the drive. That way you are not turning the gears inside the PTO unit when not needed.
There is a planet gear and sun gear that run all the time in the PTO unit. Disconecting this saves wear and tear on these parts. At least I think they do. I know some thing is turning in there at all times
Greasy John
11-13-2003 14:24:47
 Re: Re: What is the SEASONAL DISCONNECT ? in reply to Kelly C, 11-13-2003 07:00:35
Thanks Kelly, I can't find any lever on mine so it must not have been equiped with it,But maybe that is why the PTO driven gear was ate up in this tractor. Or maybe it was the fact water got in in the past and ruted up the bearings. John
