Tractor Talk Discussion Forum
Belarus Hydraulic distributor leak
Jim
11-10-2003 06:26:03
I have a Belarus 570 with a significient fluid leak around the spool valve control levers. Does anyone know the best approach for gaing access to the distributor. The distributor can be seen from the bottom of the tractor but the cab restricts access. Anyone know what has to be removed to gain acess.
Any advice appreciated.
Jim
Larry
11-10-2003 07:31:53
 Re: Belarus Hydraulic distributor leak in reply to Jim, 11-10-2003 06:26:03
Not sure how your model works. But on the bigger models the dash comes off and you can gain access
to it.
On the older Belarus's lots of guys just plumbed in a set of domestic spool valves and a loader joy stick set up. Thats what mine came with. Although I have had to replace an 0 ring on the add on the aftermarket spool valves twice. Luckly they are mounted just under the right side of the cab and easy to get at.
Jim
11-18-2003 08:18:08
 Re: Re: Belarus Hydraulic distributor leak in reply to Larry, 11-10-2003 07:31:53
Thanks Larry,
Where did you get the aftermarket spool valves and what is the brand name.
Anyone else had a good experience with an market assembly?
