Tractor Talk Discussion Forum
stuck head
mf 203
11-06-2003 17:29:40
I�m trying to get the head of my massey ferguson 203 but I can�t seem to get it of. I bouhgt it this summer and it has been sitting around for 15 years and the motor is stuck. Any tips?
Slowpoke
11-08-2003 01:10:49
 Re: stuck head in reply to mf 203, 11-06-2003 17:29:40
Use lots of PB Blaster (Walmart) or other penetrant.
wdTom
11-07-2003 17:27:58
Make sure you have the nuts off ALL the studs. If you use the twist the studs idea well just work them back and forth a bit to break them loose little by little, not in one big stud twisting off motion. It won't be much worse if you do twist off one or two, just have to mind more.
old
11-06-2003 18:52:42
You might try makeing a greese zurk set up to go in to the plug holes and then filling the cylinders with greese. But all that will do is lift the head a little but that might be enough to brake it free. Just a wild idea, I know we use to turn an engine over to pop them loose, but if your engine is stuck you can't do that. Hope this gives you some more ideas
Mike
11-06-2003 17:49:13
Those heads tend to stick to the studs. You may have to double nut the studs and back them out to get the head off.
Jerry L /az
11-07-2003 03:20:22
 Re: Re: stuck head in reply to Mike, 11-06-2003 17:49:13
If the head is stuck to the studs, by double nutting the studs, would'nt you twist the studs off? ..... ....Jer
