Tractor Talk Discussion Forum
Case 530 case o matic
Andy Meleo
11-03-2003 09:17:09
I plan on changing the fluid in my case 530 "case o matic". Is type A dextron ATF the fluid of choice? Is the plug next to the dipstick where you fill the tranny?
Ken McWilliams
11-06-2003 14:15:58
 Re: Case 530 case o matic in reply to Andy Meleo, 11-03-2003 09:17:09
Andy,
Use ATF. The clutches will work better after using it for a while. Case recommended 10 weight motor oil. The hydrans universal is close, but the ATF has friction modifiers that will help the clutch pack grip better.
I had a 420B with CASE-O-MATIC. It continued to perform better with ATF after changing out the old oil.
Roger
11-04-2003 14:11:46
Andy, not sure if type "A" is made anymore, but any ATF fluid should work, or if Case dealers have TCH fluid anymore you can use that. ATF is better in the winter since it's thinner than TCH, ATF won't turn the convertor as bad due to drag caused by stiffness of cold oil. I'm not too familiar with a 530 so I can't tell you for sure how or where to fill it, I've got an 830 & 3 930's
