Tractor Talk Discussion Forum
John Deere 2020 Hydraulic Problem
Keith
11-03-2003 06:41:12
Help! I have a john deere 2020, I removed the loader from the front to do some brush hogging this weekend and after about an hour of running hydraulic fluid started pouring out of a small round tank located under the hood above the hyd. pump. I was able to get it back to the barn but almost all of the trans/hydraulic fluid has now been pumped out. Does anyone have any ideas?
david val
11-03-2003 07:15:42
 Re: John Deere 2020 Hydraulic Problem in reply to Keith, 11-03-2003 06:41:12
the tank should be sealed, it's a part of the hydraulic system and with the engine running it's under (low) pressure.
remove the hood and look for the exact point where the oil is pouring. on top of the tank there is a banjo fitting with a plastic 5/16" hose connected to the shift lever cover. to the banjo screw should be attached a spring loaded ball valve. if this ball is missing, the pressure might pull the plastic hose off and pour out of the connection.
david
