Tractor Talk Discussion Forum
farmall c tractor
Matthew Webb
10-30-2003 09:18:59
Just finished rebuilding the engine and started up. I have to keep the chock about half open to keep it running and the throttle about half open too. the engine is surging. I have clean gas, a carb off a another c that runs good and a new gas line. Can anybody tell me what to check next. thanks matt
Farmall Nut
10-30-2003 15:51:06
 Re: farmall c tractor in reply to Matthew Webb, 10-30-2003 09:18:59
Start it up and spray WD40 around the intake wher it mounts to the head . If the intake gasket is leaking it should speed up a bit and you will find the culprit.
Bill Vanderstyne
10-30-2003 11:25:21
Sounds like you may be sucking air someplace. I had a C that surged and that was the problem.
Allan
10-30-2003 10:20:48
Again,
Or, if not that, how about a vacuum leak...manifold gasket in place?
Allan
Allan
10-30-2003 10:15:31
Matt,
Sounds like your timing is slow...
Allan
