Tractor Talk Discussion Forum
12 volt on 1949 International H
Bruce
10-28-2003 14:15:44
I was just wondering if it would harm anything to just use a 12 volt battery without changing anything on the electrical system? I dont care if it charges because I dont use the tractor that much and can just charge the battery when needed. Thanks
Irv
10-29-2003 17:06:31
 Re: 12 volt on 1949 International H in reply to Bruce , 10-28-2003 14:15:44
After a lot of thinking, what I ended up doing was putting a 12 volt voltage regulator on the generator, and a 12 volt battery. I am waiting for the lights to go out. I bought new 12v bulbs, but they haven't burned out yet - about 50 hrs tractor time now. I put a meter on the voltage leg of the generator and the generator put out 16-17 volts @ a low rpm and quite a bit higher at full rpm. Low rpm is 1000 approx. These old generators are heavily built. They will put out much more than 6v for a long time. I suspect that someday the generator will wear out, but at this rate I will be quite old. It makes a big difference in starting. The starter is real heavy built, so I never worry about that either. My 2c Irv ( my H is a 48 )
Bruce Harke
10-30-2003 10:27:08
 Re: Re: 12 volt on 1949 International H in reply to Irv, 10-29-2003 17:06:31
Thanks for the replies I have an altinator that I might throw on but I dont use the tractor that much so charging the battery isn't a problem. What kind of ballest resistor should I use?
Thanks
Bruce
irv
10-31-2003 16:04:44
 Re: Re: Re: 12 volt on 1949 International H in reply to Bruce Harke, 10-30-2003 10:27:08
I did not use one. I bought one, but never wired it in. The oddest thing was that now the ammeter shows charging at low rpm and discharging at high rpm. I think that this is because I swapped the ground. Irv
TomH
10-29-2003 16:15:13
And of course if you have lights you'll need to change the bulbs to 12v.
An alternator doesn't cost much. All you need to do is fabricate a bracket and you're there.
R. Marg
10-28-2003 14:58:23
well you should put a ballast resistor in the coil wire and un hook the genarator but other then that it would be fine
