Tractor Talk Discussion Forum
ford 1310 and a JD410 Loader??? Will it work?
Bob
10-28-2003 13:04:41
I'm looking for info on putting a JD 410 loader on a Ford 1310. I have the hyd controls but I need to know if it will fit? Clear the front end and still hit the ground. Has anyone got some help for me?
Van
10-29-2003 08:27:57
 Re: ford 1310 and a JD410 Loader??? Will it work? in reply to Bob, 10-28-2003 13:04:41
If you can adapt the mount to the tractor it will work, however the Ford used open center hydraulics and you need to change your control valves to a open center type or you will blow lines or strip the pump shaft or keyway out on the pump drive.
david val
10-29-2003 04:16:33
410 hydraulics are closed center, i don't think the the ford is. make sure you use the right valve with the rigt system.
david
