Tractor Talk Discussion Forum
Winterizing
Rex from Indian
10-24-2003 04:15:29
I have an 8N tractor I have purchased this year. I am in the middle of moving and will have to store the tractor outside this winter in Indiana.
Besides tarping the tractor I plan to drain all of the gas from it. Should I drain the radiator complete down or leave a little anti-freeze and water in it? Should I do anything elese to prepare for winter? Any ideas? Thanks
wdTom
10-24-2003 16:52:17
 Re: Winterizing in reply to Rex from Indiana, 10-24-2003 04:15:29
You have some good advise, I would add just one thing. When you get the tractor where it is going to be and want to shut it down do it by pouring oil into the carburator inlet, by the choke. Do this while reving the engine. Keep it going for a few seconds and then pour in enough to shut it down. You might use a half quart of oil doing this. This will do more for coating the valves and the interior of the engine than just putting a little in the cylinders and spinning it over. It wouldn't hurt to do this too.
DaveWis
10-24-2003 14:54:23
I agree with using fuel stabilizer, also the full tank opinion to minimize condensation. According to some reports I have recently read, gas, as it comes out of the pump, will start to deteriorate in about 2 weeks, so, for over winter storage, treatment is a must. I would test the antifreeze for ph and protection level and correct if/as needed. I would run the tractor up to operating temp and change the oil and filter. The gear/hyd oil is probably ok if it is pretty much clear of moisture. With this done I would not run it. However, if you do, make sure you warm it up good so the condensation that forms in the crankcase and exhaust will be dried out or it will cause interior rust and corrosion.
RAB
10-24-2003 08:47:31
It would not hurt one bit if you were to sqirt oil into the cylinders (when cold) and turn it over, with the plugs removed, to spread the oil around, just so everything in there has a coating of oil. If you think about it most of the oil on the bores will drain away when you stop an engine hot, so this helps to protect the cylinders and also coats the open exhaust valves, which are closest to the damp from the atmosphere.
Regards,RAB
Indydirtfarmer
10-24-2003 05:00:01
I would definatly "tarp" it. But, I would leave the anti-freeze, and gas in it. (Full tank). That way, you can start it every now and then. You might want to put the batterey in doors, if you AREN'T going to start it at all. The tarp will protect it as much as keeping it in an un-heated barn.
Al in PA
10-24-2003 06:02:23
 Re: Re: Winterizing in reply to Indydirtfarmer, 10-24-2003 05:00:01
In addition, I would suggest adding stabilizer to the gas and run some through the carb before storing. Also, block the clutch pedal down so the clutch plate isn't stuck to the flywheel in the spring.
Mike (WA)
10-24-2003 08:37:12
 Re: Re: Re: Winterizing in reply to Al in PA, 10-24-2003 06:02:23
Reason for leaving gas tank full (not half full) is not only so you can start it occassionally, but also to prevent condensation and rusting in an empty tank. The Stabilizer is about a necessity anymore, with the stuff they are using in gasoline, which seems like it gums up in about a week.
RAB
10-24-2003 08:55:11
 Re: Re: Re: Re: Winterizing in reply to Mike (WA), 10-24-2003 08:37:12
If the gas is that bad (and I think it is!) turn the gas off at the tank then drain the carb. I always drain the carbs on my kero burners. Don't leave the drain open unless you are sure your gas tank valve is perfect.
Regards,RAB
Ben in KY
10-24-2003 11:27:03
 Re: Re: Re: Re: Re: Winterizing in reply to RAB, 10-24-2003 08:55:11
I would also put black poly or other like material under the tractor to keep the moisture form rising from the ground and collecting on the covering tarp and tractor.
wvbill
10-24-2003 11:55:45
 Re: Re: Re: Re: Re: Re: Winterizing in reply to Ben in KY, 10-24-2003 11:27:03
I would test antifrezze to make sure it is good down to your coldest temp.
