Tractor Talk Discussion Forum
Tractor running rough
Rex Kinch
10-24-2003 04:09:09
I have a second question. My 8N I purchase this summer. I have mowed (bushhog)only twice with it since a got it. Once in the middle of the hot summer and then again late last week. This summer it was about 90F. This fall it was about 70F. In the summer after about 20 minutes of mowing, the engine started to run really rough a loose power. If I idled it down in netural it ran just find. The water temp. was around 175F.
This fall it ran for about 2 hours before it began to do the same thing. I first thought it sounded like the choke was stuck, but have ruled that out. Is this a overheating problem or do I have other problems to look at????? ?? Thanks for any help.
Jerry/MT
10-24-2003 14:23:39
 Re: Tractor running rough in reply to Rex Kinch, 10-24-2003 04:09:09
When did you last tune it up.Have you checked the ignition system? Some time the coils have intermitent problems, some times it's high resistance in the key/ignition switch. (Is your ignition switch hot when this happens? It shouldn't be.) Ballast Resistors can behave funny and then there is the condensor in the distributor. Your points can be burned or oily, etc. etc. By the way, why aren't you asking this question on the 8N forum?
