Tractor Talk Discussion Forum
Restoring old serial number plates
Ross Worth
10-23-2003 05:37:12
Do you know of anyone that can restore, re etch old nameplate and serial number plates? Mine are in good shape, but faint.
rw
Dan in Ore
10-24-2003 05:44:16
 Re: Restoring old serial number plates in reply to Ross Worth, 10-23-2003 05:37:12
On my F-12, I cleaned it with detergent and rinsed it well. After it dried I took a fine tip felt marker and darkened in the stamped serial number. The final touch was a couple of coats of clear enamel. It looks nice and bright and is readable. Hope this helps.
Dan
super c
10-23-2003 13:21:54
if you can get little numbers which attach to a screwdriver shaped rod, and theres a little rails which you can slide the numbers on and stamp them in with a hammer
Ross Worth
10-23-2003 17:03:01
 Re: Re: Restoring old serial number plates in reply to super c, 10-23-2003 13:21:54
Thanks for the reply, the numbers are fine it's the Case, made in, etc arround them that's faded. The black printing, or etching. Basically everything except the numbers. It's there but faint.
rw
