Tractor Talk Discussion Forum
continental engine starter
R. Marg
10-22-2003 09:22:53
well heres the problem I have a little crawler tractor it has a continental engine I need a starter for it. It's about a 1943 engine the bolt pattern for it is the same as most tractors oliver ,farmall the 3 bolt set up but it has a small hole to go in to 3.25inches most tractor starters are 3.50 and it has a short nose cone less then 3.50 inches help I can't fix this thing if I can't find a starter Any body with ideas please sound off Thanks for any and all help anybody can be
Glen in TX
10-23-2003 01:03:26
 Re: continental engine starter in reply to R. Marg, 10-22-2003 09:22:53
What is the model number of Continental engine and model and brand of crawler? Might can find something listed in my application books. Some older forklifts with Continental used a odd hard to find starter too.
Alberta Mike
10-22-2003 13:37:30
No tag on the starter for make or model number? Probably not from the sound of it. What are the center to center measurements of the 3 mounting holes from each other?
R. Marg
10-22-2003 15:01:27
 Re: Re: continental engine starter in reply to Alberta Mike, 10-22-2003 13:37:30
no starter at all a TS 1040 starter has the same mount pattern but is to long and to big around to fit the TS 1040 fits an oliver 77
