Tractor Talk Discussion Forum
Galion Road Grader
Dayton Ward
10-19-2003 20:41:17
I have a Galion ROad Grader thatis very old. I would be led to believe that the grader is probably form the very late 1800's to the very early 1900's. It has about a 7 or 8 foot blade. that is roatated by spinning a wheel on the top of the machine, the wheel sticks straight up. there is another wheel in the back that if turned shifts the back axle left to right then there are to wheels to raise and lower each side of the blade. The namepleat on it says Galion Iron Works, Galion Oh. I would appreciate any information anyone has on this great relic.
dave
10-22-2003 07:00:52
 Re: Galion Road Grader in reply to Dayton Ward, 10-19-2003 20:41:17
hi datyon where u at? theres a place in galoin yet where that was made, its called gledhill road mach. its on st rt. 309 just as u gointo galion u might check with them thay might know where u can get some info. and might check with the historical soiety for crawford co. ohio. Good luck
uglyoldfatman
10-20-2003 17:36:11
As far as I know, Galion is still in business in Galion, Oh.
Picked up a grader there many years ago.
Well, I was wrong. Did a "Galion Road Grader" search. Seems KOMATSU closed the plant in Galion in March of "99.
Try your search engine, there were a lot of hits for "Galion Road Grader".
UG!
VaTom
10-20-2003 05:05:51
Dayton, my Galion is set up slightly differently and I don't have the original hardware that let the blade rotate. It's running on radials now and has a steel tongue.
These are incredibly good graders. I have finished several new driveways. Around here, mine's referred to as "the one that came over on the Mayflower". Congratulations on your find. You planning to work it?
Mark In Mi.
10-19-2003 22:12:56
Hey Dayton,
Go to www.hcea.net for some help on your grader. The Historical Construction Equipment Association has a few graders similar to yours at the Museum in Bowling Green, Ohio.
