Tractor Talk Discussion Forum
Ford 861 vs Farmall 350
Carlton
10-15-2003 09:34:14
I was thinking about buying an 861 or a farmall.I live in the hills in montana.I am selling an 8n due to lack of power and size.Any thoughts?
Carlton
10-15-2003 21:16:24
 Re: Ford 861 vs Farmall 350 in reply to Carlton , 10-15-2003 09:34:14
Thanks for all the info.I am leaning toward the farmall but only because i Grew up on them.Iwill not be going side ways on the hills and will only get a wide front end.
R. marg
10-15-2003 18:22:44
the 2 you are asking about are rated about the same HP it depends on what you plan on useing it for fords sit lower so more sure footed on hill sides but the farmal will out pull the ford but sit up higher so on hills less sure footed and the next thing are both wide front ends you want wide front ends for hills but trickes are fine for flat only I have fords farmals olives ACs MMs and all of them can be good or bid depending on what you plan to do also farmals can be easyer to work on depending on what you have to do to them
rustyfarmall
10-15-2003 17:46:19
I have been on hills with both Fords and Farmalls, I still prefer the Farmall, they will keep going long after the Ford has lost traction, due to the Ford being lighter in weight. Yes, you can add weight to the Ford, but you can add just as much weight to the Farmall, and it will outperform the Ford.
Jeff
10-15-2003 16:43:41
Farmalls are fine for field work, but on the hills or skidding firewood here in the mountains of Pa, I'd take the Ford.
MapleStone
10-15-2003 11:51:29
When you say "hills of Montana" I think Ford.
The 350 is a tall tractor for hill climbin.
Now I have never sat on either but have used other Fords and I would say go for the 861.
Just my $0.02
rustyfarmall
10-15-2003 10:50:19
Go with the Farmall, Fords are nice, and they are built very rugged, but the Farmall will just plain outperform the Ford at any task, and will be much nicer to ride.
bobd
10-15-2003 15:45:22
 Re: Re: Ford 861 vs Farmall 350 in reply to rustyfarmall, 10-15-2003 10:50:19
I have had Farmalls & Fords over the years and Farmalls are built like an anvil but for many jobs the Fords are more user friendly. For hillside work I would use the Ford.
Tractor Dan
10-15-2003 09:46:09
i have a farmall 350 diesel one big problem is the brakes there arnt worth a poop but other than that there a good tractor
Kelvin
10-15-2003 18:59:05
 Re: Re: Ford 861 vs Farmall 350 in reply to Tractor Dan, 10-15-2003 09:46:09
I read all the other posts and I dont get it-Are you looking for an excuse to buy a Ford?
Kelvin
10-15-2003 19:03:17
 Re: Re: Re: Ford 861 vs Farmall 350 in reply to Kelvin, 10-15-2003 18:59:05
Sorry, I couldn't see all the other posts at first.
26Red
10-15-2003 11:31:49
Clean the out the disk brake housing and the brake surfaces and they work very well. The brakes don't work well with oil and grease either..
Tractor Dan
10-15-2003 16:35:47
 Re: Re: Re: Ford 861 vs Farmall 350 in reply to 26Red, 10-15-2003 11:31:49
with the tires loaded rebuild the brakes completely all new parts lasts about a week
supermpuller4
10-15-2003 16:49:17
 Re: Re: Re: Re: Ford 861 vs Farmall 350 in reply to Tractor Dan, 10-15-2003 16:35:47
You did something wrong if brakes didn't last very long, clean ramps, balls, springs, reset rod assembly and with new disc they will last years.
Tractor Dan
10-16-2003 16:48:20
 Re: Re: Re: Re: Re: Ford 861 vs Farmall 350 in reply to supermpuller4, 10-15-2003 16:49:17
when the tires where empty the brakes where ok but once i filled with fluid they arnt worth a hoot i have two niebors who have super c, 200 230 super m that where baught new and they will tell you the same thing the disks glaze over and its over
