Tractor Talk Discussion Forum
14.5 horse Briggs Stratton electrical/starter - H
Tplace
10-12-2003 14:48:20
6 year old briggs & stratton (MTD Lawn Tractor) 14.5 horse electric start. Won't crank, charged battery and replaced solenoid. Turn key and solenoid rattles and top of starter turns very very slow, but doesn't rise and engage crank. Used power assist with charger and it labored to crank very very slow and then stops, not close to starting. Is it the starter?? (starter goes for $100)
Thanks for any help.
Tplace
Slowpoke
10-14-2003 00:12:33
 Re: 14.5 horse Briggs Stratton electrical/starter in reply to Tplace, 10-12-2003 14:48:20
I had the same problem with my van recently, 20 miles from nowhere. I was unloading a 1500 gal tank from a trailer after a 100 mile trip and made several starts and stops in the process of unloading. Then nothing, no gauges, no power, no clicking of solenoid. The battery read 12v. We jumped it and it barely clicked and finally started. Sounded like it was killing the jump battery. I let it idle 30 minutes, started off and the motor quit. We jumped it again with a different vehicle with the same draining of power from the jump battery, and it finally cranked and started. I made it 100 miles to home and stopped the engine. The battery read 12v on a meter. I thought it was a hot shorted starter or solenoid, so in the morning I tried again and got nothing. Jumped it and no change. I replaced the starter and solenoid. One battery-no gauges or cranking. Double batteries-no gauges or cranking. As a last resort, I connected a new garden tractor battery to the other two. The engine started instantly. I remover the original battery and put in the small garden tractor battery. Problem gone!!! Drove around on the tractor battery two days, everything ok.
I put in a new battery and had no more problems.
I figure that the old (6-1/2 years) battery had a heart attack (short) and died within 5 minutes of the last use. That's why it was dragging down other older batteries. It never gave any indication of failing.
Try a known good battery before buying a starter.
Don't jump it, remove the old battery first.
Tplace
10-16-2003 09:40:26
 Re: Re: 14.5 horse Briggs Stratton electrical/sta in reply to Slowpoke, 10-14-2003 00:12:33
Slowpoke is right on. The battery charger said the 12 volt battery was fully charged. Before I replaced the starter, I took a chance and replaced the battery and it started right up! Thanks for the good advice.
Slowpoke
10-16-2003 11:51:10
 Re: Re: Re: 14.5 horse Briggs Stratton electrical in reply to Tplace, 10-16-2003 09:40:26
Yes it makes one fell bad when the replaced part (starter) was good afterall.
elwood
10-13-2003 15:30:26
i have a starter for you to try. you pay shipping and i will send it to you. that way you dont invest in something you dont need. if mine works on yours we can worksomething out. email me
Tplace
10-16-2003 09:44:20
 Re: Re: 14.5 horse Briggs Stratton electrical/sta in reply to elwood, 10-13-2003 15:30:26
Thanks for the offer. Turns out it was as simple as replacing the battery (charger said fully charged). Thanks again.
FROM. RITA AMANDA
08-04-2004 12:13:29
 Re: Re: Re: 14.5 horse Briggs Stratton electrical in reply to Tplace, 10-16-2003 09:44:20
FROM. RITA AMANDA
12 bp.544 cocody
ABIDJAN-COTE D'IVOIRE
west africa
([email protected])
Dear one,
With humility,I am sending you this mail
expressing my sentiments. I am the daughter of General AMANDA. the former military interior minister of my country Cote D'Ivoire who was assasinated with general DOUGLAS TUKOR (former military president)by the forces loyal to the Government of Laurent Gbagbo on 19th September 2003.
It was based on the assasination of my father coupled with the arrests and harrasment on me by the security agents of the present government since the death of my father that prompted my writing you this mail.
Iam seeking your assistance as regards the deposit made by my late father in a bank here in Abidjan-Cote d'Ivoire .It is a deposit of ($10.500 .000) Ten million five hundred thousand us dollars and i want to urgently transfer this money to your country so that i can leave there for security of my live.
And after the transfer i will come to live and continue my school in your country. All i need from you is to assist me and provide an account where this money will transfer You will also assist me in investing the money in your country since I have no business ideas.
my education is a very essential as i will like to finish up my schooling and to further because that was my late father's plan for me before his death.
Please your urgent reply will be appreciated to enable me tell you on what next step to follow.
Thanks and God bless you RITA AMANDA
tlak
10-12-2003 16:32:24
The way the starter works is when it engages the top or drive pushes away from the engine so over time the upper bushing wears and allows the internal parts to lock against each other. The upper part of the starter is $50-60 and the bushing if you get somebody to order is $20-25. Had a machine shop put one in for $15. The other thing is you need to put juice right to the starter with your power source and see what it does, the cable at the starter might be loose or corroded.
