Tractor Talk Discussion Forum
3pt lift arm installation question
Tim
10-12-2003 12:17:15
I am installing new lift arms on my first tractor, and would like to know if it matters how they go on. For instance, I notice that when mounted the ends that attach to the implement can either turn slightly in or slightly out, depending on which way you mount them. Is there a right or wrong way. This is on an older IH tractor.
paul
10-13-2003 05:19:08
 Re: 3pt lift arm installation question in reply to Tim, 10-12-2003 12:17:15
Well, the ball ends should end up _parallel_ to each other when in use, so the angle on the outer end should be inward. You would be calling it 'slightly in'.
--->Paul
twopop
10-12-2003 15:50:49
the ends of the lift arms should turn in towards each other
