Tractor Talk Discussion Forum
Distributor Breaker Plate
tom
10-10-2003 17:42:18
Have a 1950 TO-20 Ferguson that needs a new distributor breaker plate. All info that I have gathered indicates that the plate is no longer available and the only way to replace it is to install a new distributor assy.
Any suggestions or sources of this part?
Glen in TX
10-12-2003 09:12:37
 Re: Distributor Breaker Plate in reply to tom, 10-10-2003 17:42:18
Tom, I have some new old stock dist. breaker plates for Autolite and some other brands of distributors in the Niehoff replacement brand. Would need to know the numbers off your dist. to see if I have any that would match up.
Dave
10-11-2003 16:40:36
What brand distributor did they use on them? Are there any tags with numbers on it?
Tom Guess
10-13-2003 20:59:30
 Re: Re: Distributor Breaker Plate in reply to Dave, 10-11-2003 16:40:36
it corresponds to this number in a ferguson tractor book 1 750 437 m1
Tom Guess
10-13-2003 20:59:06
it corresponds to this nubers in a ferguson tractor book 1 750 437 m1
Nebraska Cowman
10-11-2003 04:01:51
try finding a used distributor.
Tom
10-11-2003 07:39:40
 Re: Re: Distributor Breaker Plate in reply to Nebraska Cowman, 10-11-2003 04:01:51
i dont care if it is used or not i just need one in good shape
RAB
10-11-2003 01:33:53
Are you saying there is no plate at present or the plate is broken in some way? If it is broken, then fixing it may be an alternative. Or get a distributor off a scrap engine and either fit that or use the plate on your dist. There are plenty available in UK where the distributor was used on car engines as well.
Regards, RAB
