Tractor Talk Discussion Forum
Mixing calcium chloride
Dieselrider
10-02-2003 16:56:49
Does anyone have any experience mixing their own calcium chloride with water and filling their own tractor tires? What would the right amount per gallon of water be, how much mixing is required, and how do you get it into the tire without a calcium pump. Would raising a loaded drum in the air above the tire, stopping every now and then to let the air out, create enough pressure to fill the tire? How about a windsheild washer pump? Any ideas?
Bob Clark
10-04-2003 14:16:28
 Re: Mixing calcium chloride in reply to Dieselrider, 10-02-2003 16:56:49
I have actually used a nylon roller spray pump to pump calcium into tractor tires. You need to know up front of course this is a one time deal, the pump will be shot after it sets for a couple of days.
Ray,IN
10-03-2003 21:12:14
No advice on CCl, except to install new inner tubes every 10 years to avoid leaks that destroy your rims. Have you investigated the new alternative? It's non-toxic, non-corrosive, and the specific gravity is the same. Farm tire stores will have detailed information.
george md
10-02-2003 20:59:39
Dieselrider,
Don't know where in pa that you are but
take your drums with you , Martin tractor in
newville has cacl taken out of tractors they
junked ( free ) .
george
buickanddeere
10-02-2003 19:29:32
Unless it's a loader tractor that requires extra rear ballast, external cast weights are superior. The calcuim chloride solution after mixing should be spread on the road to limit dust. Then fill the tires with beat pulp or windshield washer fluid. Won't have a rust problem either.
Robert in W. Mi
10-03-2003 14:16:39
 Re: Re: Mixing calcium chloride in reply to buickanddeere, 10-02-2003 19:29:32
I just bought a tractor from an elderly friend. He had the rear tires loaded "over" 30 years with cal. ago! When i got the tractor home, i had my tire man take the tires off the rims, as i wanted to see the condition of the rims, and guess what? NO rust!!
I also have several other tractors with cal. and NO rust, so there's "nothing" wrong with cal, it's the owners that's the problem!!!
FIX all leaks right away and wash the rims with soap before putting the tires back on, I've always done this, and i never had "any" problems with rust at all!! Robert
Rod (NH)
10-02-2003 17:51:15
Hi Dieselrider,
I have mixed up and installed my own CaCl solution in tractor tires. You use about 2-3 Lb CaCl 77% Flake per gallon of water. See this pdf file from Dow Chemical. The freeze point shown for various mix ratios does not have to equate to the lowest ambient temperature for your area. My area occasionally gets to -20 deg F but a mixture with a freeze point of +10 deg F is quite satifactory. A slush will begin to form at +10 but the solution will not freeze solid at -20. The fact there is slush in the tire will not be a problem.
You just mix it all up by stirring until all the flake is dissolved. The mixture will get warm in the process .
Yes, you can elevate a drum so the solution will flow by gravity into the tire. Keep the valve stem in the top vertical position and vent off air every once in a while. Use the special fill fitting for this purpose. I have used a 50 gal drum elevated in a front bucket loader successfully this way. It's slow but works. I have also used a small Simer pump (garden hose connections) to do the job. That's a faster way but is not really necessary if you are doing the work for yourself and don't mind taking some time. If you use any kind of pump, make it a cheap throwaway unless it is an expensive pump designed specifically for CaCl solutions.
third party image Rod
marlowe
10-02-2003 17:12:47
i user hope your in wisconsin because i have a deal for you!!!!! !!!! FREE yes FREE 150 gal. of one owner calcium chloride. if your close i well bring to you
Ryan
10-02-2003 19:40:38
 Re: Re: Mixing calcium chloride in reply to marlowe, 10-02-2003 17:12:47
Marlowe, where in WI? I may be interested!
marlowe
10-03-2003 16:56:26
 Re: Re: Re: Mixing calcium chloride in reply to Ryan, 10-02-2003 19:40:38
fremont 27 miles west of appleton
Dieselrider
10-02-2003 19:30:57
Marlowe,
I wish I were closer than I am but, I'm in central Pa. a little farther than you are willing to deliver I bet.Thank you for the offer anyway, I really do appreciate it.
marlowe
10-02-2003 17:14:58
i [sure] should have been
