Tractor Talk Discussion Forum
OC3 Wide Track Crawler Clutch Problems
JED
09-26-2003 10:00:14
While attempting to dig out a small pond, my OC3 suddenly decided to start grinding when I tried to shift gears. I lowered the speed thinking that the clutch was slipping and I might be able to get it in reverse to get out of the hole and back to the shed. This however didn't help. After hooking several chains together I pulled it out with the M. The clutch pedal moves in and out with ease, too easily that is. Does anyone have a feel for what is going on.
DaveS
09-26-2003 10:57:07
 Re: OC3 Wide Track Crawler Clutch Problems in reply to JED, 09-26-2003 10:00:14
Might be the forks that hold your throw out bearing. I had a Oliver 99 break one side and it was enought to keep the clutch from disengauging properly. Is there a cover on the bellhousing that you can open and get a light in to see?
Just thinking out loud.
