Tractor Talk Discussion Forum
12v wiring diagram for 8N Ford
Mike,MS
09-25-2003 20:54:11
I am in need of a 12v conversion wiring diagram for a 8N Ford...does anyone know of or have a site that I might could find this drawing?
Thanks-
Mike
Frank
09-26-2003 23:54:24
 Re: 12v wiring diagram for 8N Ford in reply to Mike,MS, 09-25-2003 20:54:11
Don't know the need for a wiring diagram to convert original 6 Volt to 12 volt. I just replaced the 6 volt generator with a 12 volt Delco alternator with internal regulator that only needs a single wire out plus an field excitation via a switch or through a instrument panel light.
Then, you need a step down resistor or what is called a balance resistor to cut the voltage to the distributor at run to 6 -9 volts or the contact points will burn. And of course if you have lights, you have to change the bulbs to 12 volt. There's no real need to rewire, only rebulb and add the alternator and the balance resistor that's available for cars without solid state ignition.
Mike
09-27-2003 10:44:09
 Re: Re: 12v wiring diagram for 8N Ford in reply to Frank, 09-26-2003 23:54:24
Thank you Frank...I will try this...
Mike
Bob
09-26-2003 07:06:46
Link
Mike
09-27-2003 10:44:56
 Re: Re: 12v wiring diagram for 8N Ford in reply to Bob, 09-26-2003 07:06:46
Thanks for the info Bob...
Mike
