Tractor Talk Discussion Forum
What is a Flail mower?
Roastnear
09-24-2003 19:27:23
Saw this in a classified ad. my Guess is a bush hog but there's another one of those terms that means one thing where i live and somthing else where others live. Roastnear
tommy
09-27-2003 17:41:13
 Re: What is a Flail mower? in reply to Roastnear, 09-24-2003 19:27:23
Thanks For the info. the road dept. here dosen't use them they favor the bush hog on an hydrolic arm they cut heavy over grow low tree limbs small trees looks like a tornado has went through think i'll pass on the ad -rostnear
Bob Semrau
09-25-2003 19:27:55
Flail mowers do a much better job than a rotary cutter, but don't buy a used one until after you have seen it hooked up to a tractor and run at PTO speed without vibrating itself to death. I found this out the hard way - at least I have lots of spare flails now, as I ended up having to buy another one, as the first one I bought had a bent cutter shaft ...
MarkB
09-24-2003 22:29:19
Check out the Alamo (formerly Mott) site for some pictures.
Flail mowers are quite a bit more expensive than rotary finish mowers and brush hogs. They have a number of advantages, however. They do a better job of picking up grass that's been flattened by the tractor's tires, and they don't leave any windrow. Since the shaft is horizontal instead of vertical, trash is not thrown to the side, a big consideration in highway mowing.
If you're considering the purchase of a used flail mower, check out its condition carefully as parts can be pricey.
When con
bob
09-24-2003 21:21:22
sometimes see them mowing along Interstates with rear mounted & side mounted on the same tractor
paul
09-24-2003 20:37:45
'Flail' around here would be a bunch of knives on a spinning shaft to cut the grass. Like a corn stalk chopper, or a straw chopper on a combine, if you are familiar with farm stuff.
Different than a bush hog.
--->Paul
Pitch
09-25-2003 03:43:35
 Re: Re: What is a Flail mower? in reply to paul, 09-24-2003 20:37:45
To put it simply a flail mower has a horizontal shaft with chains fastened to it. The chains have small chunks of metal attached to the ends.It rotates like a rototiller would and "Flails" the grass.Hiway departments use them because they are much more forgiving than a brush hog when they contact rocks or other debris. They won't fling a section of metal fence post out the side into someones car. I would check it out carefully before buying a used one as most I have ever seen for sale are quite beat.
