Tractor Talk Discussion Forum
real wheels
Bob
09-24-2003 12:30:09
I want to switch the wheels on my ford 640 to give it a wider stance. They contain no ballast.I have no idea how much a tire and wheel weigh. Is it a problem for one person to roll a wheel around to the other side of the tractor? If I drop it on the ground, will I be able to stand it up without help?
Jim.UT
09-24-2003 15:46:08
 Re: real wheels in reply to Bob, 09-24-2003 12:30:09
It shouldn't be a problem if all they have in them is air. It's when they're filled with liquid that it gets fun! If you drop it, you should be able to pick it up again. If it's filled, be prepared to have help if you drop it. A filled tire can weigh about 500 lbs.
You'll have an easier time if the tractor is parked in the garage or shop with a nice smooth cement floor. Still do-able in the dirt or gravel, though.
bob
09-24-2003 21:23:24
 Re: Re: real wheels in reply to Jim.UT, 09-24-2003 15:46:08
wheel weight adds about 50 lbs. to tire
