Tractor Talk Discussion Forum
Jacking a Farmall B
Tom in Texas
09-23-2003 17:13:23
Now with the cracked block problem under control I need to jack the front wheels off the ground of a 1946 B Farmall. Right now my plan is put a 4 by 4 on top of the floor jack and locate it under the bell housing and jack the front wheels off the ground. I'm cleaning and repacking the front wheel bearings and installing new tires. Is the bell housing strong enough to support the weight? Thank you in advance for your help.
Red Dave
09-24-2003 06:02:23
 Re: Jacking a Farmall B in reply to Tom in Texas, 09-23-2003 17:13:23
It's strong enough. That's what I do to jack the front end of my B. There really isn't anyplace else to jack against, unless you want to jack on the oil pan, which I don't reccomend.
Tom in Texas
09-23-2003 17:23:22
The tractor is on a trailer right now. I don't have a lot of manuever room.
JohnTX
09-23-2003 17:20:53
Tom put a 2X6 in front of one wheel and push the tractor up on it and then work the other wheel. Do one at a time.
John
big fred
09-24-2003 07:28:57
 Re: Re: Jacking a Farmall B in reply to JohnTX, 09-23-2003 17:20:53
That's what I do, works great if you are doing one wheel at a time. If for some reason you need both wheels off the ground, a jackstand under the clutch housing works fine.
