Tractor Talk Discussion Forum
Waterglass block repair results
Tom in Texas
09-23-2003 14:36:03
The response to my request for help with the block repair using waterglass has been tremendous. Thank you all very much. I appreciate the input. Being new to all this and based on everyones input I have elected to go with the JB weld and some BARRS block stop leak. That should hold me untill I can get a work shop built and overhaul the tractor. Once again thanks everyone for all your input.
Nolan
09-24-2003 03:04:19
 Re: Waterglass block repair results in reply to Tom in Texas, 09-23-2003 14:36:03
Barsleak is my personal preferred bandaid. It certainly isn't a permanent fix, but it's also very removable with a quick flushing of the garden hose.
Tom
09-23-2003 21:33:34
If you use one of the stop leak products, be prepared to have a full rod-out done on the radiator at a professional shop when you do your overhaul. Been there - done that.
Larry806
09-23-2003 20:25:16
I wasn't trying to tell you to use it I was just telling you what I know about useing it. I would weld it myself Glar you got a lot of info to work with Larry
twopop
09-23-2003 19:32:06
if you want the block to seal,use DYKE by CONKLIN
earlschieb
09-23-2003 19:46:07
 Re: Re: Waterglass block repair results in reply to twopop, 09-23-2003 19:32:06
Nothing better than Dyke !!!! Makes Bars Leak look like you added nothing at all, and yes, Dyke is that good.
