Tractor Talk Discussion Forum
Need Massey Ferguson Help
Lynn
09-23-2003 12:23:06
My 699 is leaking a ton of Hydraulic fluid. I have replaced numerous o-rings on the hoses going into the hydraulic control valve, but it doesn't seem to help. Has anyone ever had this problem and what is the best cure?? The hoses have a type fitting that you push into the control valve then are held in place with a u-shaped keeper. Thanks for any help
rod
09-23-2003 13:19:53
 Re: Need Massey Ferguson Help in reply to Lynn , 09-23-2003 12:23:06
I have only worked on my MF 220 backhoe and found that the control valves are stacked that is there are orings between each section and all kinds inside it. I also found quite a few hoses were shot only way to find out is to clean it all up very good and then look for source of leak a shop manual is a must for this type of work also if you get old orings out they can usually be matched by a hydraulic shop much cheaper than the dealer. Not the answers you want but that is all I know. PS has to be very clean for disassembly and mark all hoses as you take them off.
regards
rod
Lynn
09-24-2003 05:08:57
 Re: Re: Need Massey Ferguson Help in reply to rod, 09-23-2003 13:19:53
Thanks Rod. I have replaced the o-rings on the ends of hoses I will check for more on up in the control valve.
