Tractor Talk Discussion Forum
Ford 5000 broken PTO shaft
craig
09-17-2003 13:09:29
I recently broke the PTO shaft on my Ford 5000. Can someone out there offer me any assistance on what is needed to install the new shaft?
Thanks!!
Rod F.
09-17-2003 20:55:56
 Re: Ford 5000 broken PTO shaft in reply to craig, 09-17-2003 13:09:29
I assume you mean the output shaft, 540 only. You'll have to pull the lift rocker, and the right hand axle, to get access from in front to get the driven gear off. Then take the bearing retainer off and pull the shaft. Drive shaft will pull out from access cover forward of top link rocker. If you have 540/1000, just pop the circlip, and haul the stub out. Be sure to block and support the tractor well when you go to take the axle off. Probably need a little crane or boom to lift the axle, or a few real strong bodies. I'm thinking 500#, give or take. Hope this helps you out.
Rod
Gary-Miss
09-17-2003 20:54:45
I would probably start by lifting the top cover off the transmission. The pto ON A 5000 IS operated by a piggyback pump on the hydraulic pump and then it has a cutch about like the clutches in an automatic transmission just under the cover. You can at least see everything under it from that point. Don't forget to remove the bolt under the right lift arm that's kind of out of sight.
