Tractor Talk Discussion Forum
Magnetic Oil Pan Heater
Dave
09-13-2003 10:27:32
Is there a good place online to buy these?? need one for a pickup truck
Dave
Tractor Dan
09-14-2003 09:14:47
 Re: Magnetic Oil Pan Heater in reply to Dave, 09-13-2003 10:27:32
i have 2 they dont work that good but boy do they make the meter spin coolant heater is much better
Glenn-WV
09-13-2003 22:11:44
I agree with Lee - you want something that heats the coolant. The freeze-plug heaters do a good job, but you have to remove one of the freeze plugs and replace it with the heater. There is a heater that fits inside the lower radiator hose. I added an external tank heater to my truck. It takes coolant from the block drain, heats it, and pumps it into the return line from the cab heater core, heating the engine. It does a good job.
You can get these heaters from a good auto parts store, like NAPA. A rule-of-thumb for wattage is to multiply the engine displacement by three and buy the next-higher-wattage heater.
Lee
09-13-2003 19:30:06
Your are wasting your time and money on this type heater .. If it's cold where you live this heater will not heat your oil or water in your engine. Buy a block heater that goes in a freeze plug hole . Or a heater that pumps the heated water thru your engine.
