Tractor Talk Discussion Forum
gas boiling
joe
09-08-2003 06:10:09
I have 135 massey ferguson with a 3 cylinder perkins. After an hour or so of working this tractor the gas starts to boil in the settling bulb causing the tractor to vapor lock and shut off. Until this happens the tractor runs real well. does anyone know what might be causing this? THANKS, Joe
Nebraska Cowman
09-09-2003 04:44:01
 Re: gas boiling in reply to joe, 09-08-2003 06:10:09
are you and I the only ones that have seen this? I have a TO 20 and have seen gas boil in the tank. On a hot day it will boil right along. Try adding about 10% diesel.
marlowe
09-09-2003 18:55:35
 Re: Re: gas boiling in reply to Nebraska Cowman, 09-09-2003 04:44:01
my to-20 has done that for 50+ years
edwin
09-08-2003 13:31:39
Wheather it is gas or diesel is the fuel boiling or is air being bubbled through it . air could be drawn in if there is dirt blocking the tank outlet, dirt might build up on the strainer in the tank while in use and fall to the bottom when stopped .Ihope this is of help
Ben E.
09-08-2003 07:41:56
Copper fuel line? Missing heat shield? Tractor running too hot? Is the sediment bowl at the tank or at the carburator? Fuel line too close to the exhaust manafold or muffler? One or more of these symtoms is causing the fuel to get too hot either in the tank or in the line going to the sediment bowl.
Good luck
Ben E.
Kennyp
09-08-2003 07:40:08
What? what? 3 cyl Perkins and gas ???
Isn't that a diesel engine?
CH
09-08-2003 12:43:37
 Re: Re: gas boiling in reply to Kennyp, 09-08-2003 07:40:08
Perkins made both.
RAB
09-08-2003 15:51:13
 Re: Re: Re: gas boiling in reply to CH, 09-08-2003 12:43:37
Never come across a gas engine made by Perkins.
CH
09-08-2003 16:57:53
 Re: Re: Re: Re: gas boiling in reply to RAB, 09-08-2003 15:51:13
Here they are:http://www.perkins.com/Cat_World/assets/media/perkins/Engine_Number_Guide_English2.pdf
Massey used them for a while.
AG3.152, just about the same as the diesel. Water pump and power steering pumps are interchangable.
Ben in KY
09-08-2003 10:20:17
That was my thought too. Diesel ??
