Tractor Talk Discussion Forum
Farmall B transmission
dan agius
09-07-2003 19:09:34
I have a 1944 Farmall BN and it is stuck in 4th gear. Any information would be appreciated.
gene b
09-08-2003 03:14:44
 Re: Farmall B transmission in reply to dan agius, 09-07-2003 19:09:34
drive the pin out where the shift lever pivots lift the shift lever out and look inside you will see the rails they want to be all lined up this will be in neutral. Your pin that you drove out may be worn or the end of the shift lever needs to be built up. Tying the clutch depressed will help in moving the shift rails to the neutral position. You can also remove the top cover of the transmission instead of removing pin.
