Tractor Talk Discussion Forum
Ford hydraulics
Bob
09-06-2003 12:57:47
I have a Ford 1700 with a front end loader and just purchased a 20 year old backhoe that was unused for the last 5+ years. When I connected it, nothing moved, even the front end loader wouldn't work anymore.
When I reversed the in/out hoses on the backhoe, weak movement was noted in some of the cylinders. After disconnecting the QD, loader ops returned to normal. Any ideas of what I should do next?
geok
09-06-2003 14:17:44
 Re: Ford hydraulics in reply to Bob, 09-06-2003 12:57:47
Depends on how you are trying to connect. If you are Teeing in to your system the response that your describe will happen. You will have to complete the circuit. From the return on loader valve to the B/H then back to reservoir or if equiped from your power beyond on loader valve to B/H. If you are using quick couplers, kill engine before connecting or disconnecting.
rod
09-06-2003 13:54:12
probalby need more fluid to run the cylinders out more also probably all o rings are dried out and either leaking or ready to I just am doing mine up and it was used very little for years so far have spent 150.00 on orings put two new hoses on stabilizers and today blew gasket out of the swing motor this is now a major repair and no more unused machines for me.
regards
rod
