Tractor Talk Discussion Forum
Oil in water
Mark
09-05-2003 09:48:28
I have a 722 Bobcat that was in a flood. It now has a new engine. Both the gas tank and the hydraulics got water in them. I used gas line drier chemicals and a fuel seperator on the fuel system, although there is still some water it seems to run fine. But the hydraulic system is a different story. I drained the storage tank and put in fresh oil. The question is how can I get the rest of the water out of the pump and lines? Are ther any chemicals or can I just open lines until they pump clear. Amazingly everything works fine despite the water.
Any ideas would be appreciated.
rod
09-05-2003 10:14:20
 Re: Oil in water in reply to Mark , 09-05-2003 09:48:28
there is a type of methyl hydrate for truck air brake systems supposed to not harm rubber or seals any truck stop should have it of course best way is likely flush with diesel a few times then put new in it.
regards
rod
