Tractor Talk Discussion Forum
bent rod on kohler engine
kraig
08-31-2003 15:34:48
I am going to work on a kohler engine off a toro lawn mower. I was wondering if I could get some ideas, a guy was mowing with it and a rod bent, just was wondering where to start looking
Kraig
09-01-2003 06:24:13
 Re: bent rod on kohler engine in reply to kraig, 08-31-2003 15:34:48
Stupid me, I should of said push rod,
Gary-Miss
08-31-2003 18:28:01
Most any small engine dealer can get you a rod. When you replace it, start using 5W-30 oil instead of straight30. These rods are kind of fragile and they don't like to stir that thick 30wt oil when it's cold. If you have some of the rod stuck to the crankshaft (or piston to the cylinder wall) you cantake it off with a bit of Muriatic acid. It will rust stuff like crazy, so, be sure to spray everything down good with WD-40 as soon as you get it off.
