Tractor Talk Discussion Forum
Ford 800
Mo in wi
08-29-2003 07:29:25
Hi, I am looking at a Ford 800 to purchase. It is supposed to be a later model, live pto, 3 point, 5 speed trans. etc... I am hoping to use it to pull a 7 foot haybine- will it have enough power for that? (I have about 12 acres of hay ground.) Also, I have some of the hay made into round bales. I have my choice of 400# or 1000# bales. Is there any way I could move these bales with this size tractor? If so, how?? Thanks, Mo
paul
08-29-2003 10:32:22
 Re: Ford 800 in reply to Mo in wi, 08-29-2003 07:29:25
You must be looking at an 860 - altho a 'later model' would maybe be a 861? I'd sure want to know before purchasing..... .
I have a 960, which is a row crop version of what you are looking at. It pulled my 1209 moco, altho the pto got weak & it doesn't now, getting a new clutch would make it handle it fine.
I also move round bales at times with it. I use a fork-lift type 3-point bale mover. You could go for the spear-type also. It can make the front end _very_ light, you would want some weight on your front end. Also will require the tractor to be in good shape with a good hyd pump & all. You would be best to remember to drive slowly, that will be a lot of weight on your rear axle, you don't want to drop in a gopher hole at speed.
But, a good shape 800 series should handle the tasks for small acreage.
--->Paul
Rod F.
08-29-2003 08:02:27
Sounds like an 860. It should handle the haybine OK, as long as you don't have any bad hills. Be aware that the PTO shaft on that tractor is 1-1/8, not 1-3/8, so you need the adapter. As for the bales, it will probably handle the 1000# ok, but not much more on the 3 point, unless you have front weight. I used to handle 4x4 silage bales with ours, and it was dicey. Front tires didn't receive much wear when there was a bale on the back. They would have been 1200 - 1500# bales. Check the tractor over well, and good luck.
Rod
Dave@NY
08-29-2003 18:16:03
 Re: Re: Ford 800 in reply to Rod F., 08-29-2003 08:02:27
We have a tractor like that,it is a model 861.But the PTO is 1 3/8" and it also has power steering.
